1992 Lexus LS 400 Pads
195,000 MILES • V8 • 2WD • AUTOMATIC
92LEXUS400LS4RON
just did the change out myself and now the car basically feels like it has no brakes. what did I do wrong. Vice gripped line at caliper, removed and drained caliper, moved pistons back, installed new pads, reassembled attahced brake line first and then released the vice griip.
what did I miss... THx
May 29, 2008 at 9:09 AM
BLACKOP555
  • 10,386 POSTS
chances are you wrecked the brake lines from using the vice grips, what would make you do that?
secondly after the lines are replaced the brakes will have to be bled, then it should be good to go.
May 29, 2008 at 11:35 AM
