1992 Lexus LS 400 MY Battery
1992 LEXUS LS 400
128,108 MILES • V8 • AWD • AUTOMATIC
MOOLEXLS400
My name is Nick and I own a 1992 Lexus LS400. If I leave my car on without the engine running for about 45 minutes my car will not start. I thought my battery was dead because my over head light seemed a little dim, but the mechanic told me that my battery was fine. Does anyone know what the problem is please let me know.
Thank You...
Apr 4, 2009 at 7:11 PM
KEVINSTOYOTALEXUS
  • 5 POSTS
When you say it won't start, does it crank or does it crank slow? If it's a cranking problem, please see below.
For my 91 LS400, I condemned a few batteries before I realized the startor motor itself was bad. Mine lasted almost 200,000 miles. This isn't an easy job. The starter is located in the intake manifold and is a very expensive repair. If you have checked and confirmed all power and grounds are clean and tight, and the battery and alternator are ok, then you probably have a tired starter motor. I, personally, would recommend a new Lexus starter whether you or someone else installes it.
Good luck
- Kevin
May 4, 2009 at 7:43 PM
