1995 Lexus ES 400 how to replace the front brakes.
95,000 MILES • V8 • 2WD • AUTOMATIC
MODIFIEDMAN
I need to know how to replace the front brakes on this car.
Thanks
Don
Dec 15, 2009 at 12:48 AM
ERNEST CLARK
  • 1,730 POSTS
Here's the replacement procedure. If you've never done this before, I recommend you buy a service manual for your vehicle. It'll have detailed illustrations of the parts and tools needed.
Remove caliper bolts from torque plate, Figs. 1 through 3, then the caliper. Suspend caliper securely. Do not let caliper hang by brake hose.
Install the following
Two anti-squeal springs, if equipped.
Two brake pads.
Four anti-squeal shims.
Two pad wear indicators.
Four pad support plates.
Install pads as follows:
Install wear indicators if necessary.
Apply disc brake grease to both sides of inner anti-squeal shim.
Install anti-squeal shims to each pad.
Install pads with wear indicators facing downward.
Install anti-squeal springs if necessary.
Remove small amount of brake fluid from reservoir.
Using suitable hammer handle, press piston in.
Insert caliper and bolts. Tighten caliper bolts to specifications.
Install wheel. Tighten wheel lug nuts to specifications.
Fill brake fluid reservoir.
Mar 3, 2010 at 11:35 AM
