1994 Lexus ES 400
12,000 MILES • V8 • 2WD • AUTOMATIC
YANGEJW
I have Lexus 1994 LS 400 with 120,000 miles and It apperas to have the same problem as you have.
No power with gas smelling in the engine compartment.
Did you figure it out?
Apr 8, 2009 at 5:51 AM
ERNEST CLARK
  • 1,730 POSTS
That's either a leaking Fuel Pressure Regulator or an leaking injector.
Pull the vacuum line that leads to the FPR and smell/feel for the presence of Gas. If there's any, replace it.
To check the injectors, hook up a fuel pressure gauge, block off the return line and vacuum line of the FPR, turn the Key on/engine off and read the pressure of your system. If the pressure doesn't hold steady, one/more of your injectors are leaking.
You could replace one injector at a time. But if there's more than one leaking, I suggest you replace them all. If you don't, you'll have driveability issues, as it's hard for new injectors to balance correctly with old injectors. And your computer can't always compensate for the imbalance.
Mar 3, 2010 at 1:01 PM
