1990 Lexus ES 400 want stay on
1990 LEXUS ES 400
BARRERAALEX
Engine Mechanical problem
1990 Lexus ES 400 V8 Two Wheel Drive Automatic 175k miles
it starts and runs but whene you get to a stop it shuts off . the rpms like at 400 whene you turn it on
Dec 19, 2008 at 12:28 PM
ERNEST CLARK
  • 1,730 POSTS
That r.p.m. is normal. But is your check engine light coming on??? If so, you need to have the computer scanned.
This could be an ignition, fuel, sensor, or computer related issue. To guess at this point wouldn't do you any good.
Begin with having your computer scanned for codes. If there's codes present, get back with me and I'll walk you through the definitions and any repair procedures.
If there's not, check your engine's systems in the order I listed above. When you isolate the fault, write back and I'll help you from there.
Mar 3, 2010 at 1:12 PM
