HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Lexus
ES 300
Engine
Symptoms
Not Cranking Over
1997 Lexus ES 300 engine won't crank or cranks slowly
SHAYAN
MEMBER
1997 LEXUS ES 300
6 CYL
2WD
AUTOMATIC
192,000 MILES
Engine won't crank or cranks slowly? Any help
Wednesday, June 17th, 2009 AT 12:05 PM
BSCHURR
MEMBER
Have you replaced the battery?
Thursday, June 18th, 2009 AT 1:43 PM
SHAYAN
MEMBER
Yes New Battery, and New Starter, New plugs, Air Filter but car still wont start. When I try to start battery terminals gets very hot.
Thursday, June 18th, 2009 AT 4:07 PM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
2003 Lexus Es 300 Not Starting Or Turning Over
It Started Went To Store Then Didnt Want To Start, Just Not Turning Over. Everything Works Lights, Radio, Ac. Battery Is Good Its Not...
Asked by
victor acosta
2003
LEXUS ES 300
VIDEO
Car Not Cranking? Try This | EASY
Instructional repair video
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
2000 Lexus Es 300 Engine Will Not Turn Over
2000 Lexus Es300 -- When I Inset The Key To Start, All Electric Is On, When I Turn The Key The Engine Will Not Turn Over. When I Turn The...
Asked by
rx4800
1 ANSWER
2000
LEXUS ES 300
1999 Lexus Es 300 Car Fails To Turn Over
About 8 Days Ago Car Died. I Was Driving At About 55 Mph With The Acceleration At 2.5. Without Warning The Acceleration Dropped To 0 The...
Asked by
johngalt
1999
LEXUS ES 300
Starter Not Working ?
I Know It's Not The Battery Cause All Lights Were Working Properly And Battery Was Tested. Car Does Not Crank When You Turn Ignition.
Asked by
YoliRosales
2003
LEXUS ES 300
1999 Lexus Es 300 Car Won't Turn Over Lexus Es300
1999 Lexus Es 300 140000 Miles My Car Sounds Like It Wants To Turn Over But Will Not. I Replaced The Battery And Fuel Filter And Its...
Asked by
mandarossis
1 ANSWER
1999
LEXUS ES 300
VIEW MORE
Battery Test
Starter Motor Replacement
