1992 Lexus ES 300 thermostate
SAULSBERRY
  • 1992 LEXUS ES 300
Engine Cooling problem
1992 Lexus ES 300 4 cyl Front Wheel Drive Automatic
were the thermostate on the es 300
Monday, March 9th, 2009 AT 2:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Your vehicle's thermostat is located on the passenger side of the engine compartment. Follow the lower coolant pipe starting from the radiator into the engine and thermostat is located where that pipe enters the engine. You will have to remove the windshield washer reservoir, alternator drive belt and remove any engine mounting components will greatly help. The thermostat housing is secured by three bolts and also remove the bolt that holds the metal pipe connecting to the alternator bracket.
Thanks for using 2CarPros. Com!
Monday, March 9th, 2009 AT 2:27 AM
