level of cvt oil
20,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
MACGREGOR
If when the engine is in park and idling after going through the gears and the cvtf oil is between 35-45 Celsius, when the fill plug is cracked if a little bit of oil dribbles out is the reservoir at the sufficient level I ask because some of the cvt oil was drained by accident, consequently I do not know how much was removed.
Jan 29, 2018 at 7:55 AM
STEVE W.
  • 15,394 POSTS
That level should be fine as long as the vehicle was level.
Jan 29, 2018 at 9:14 AM
