left brake light works but not the right
304,343 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFREYJOLLEY
Left brake light works but not the right put in new bulb but still have same problem abs light is on does that mean anything?
Jan 2, 2015 at 1:04 AM
HMAC300
  • 48,601 POSTS
if abs light is on it means there is a problem with it but you will still have brakes just not abs. have a pro scan for codes. for brake light check ground going t that light it may be bad ,corroded etc.
Jan 2, 2015 at 1:33 AM
