Okay. This sounds like condensation from the air conditioning system and possibly the exhaust. This is absolutely normal. The AC system will condensate when it is running and then when you park the vehicle the remaining water on the system will drain off onto the floor. Also, the exhaust will "sweat" as well and can leave this water on the floor.
If you are concerned about it, just check the level of your fluids but again, you will not find this clear liquid in any of your systems unless you put just straight water in your cooling system which is never recommended so I am sure this is just the normal water that comes off these two systems.
If you want to take a picture of it and let me look at it, I will be happy to take a look but I am sure it is fine based on what you described.
Jun 22, 2019 at 3:24 AM
