Leaking seal on the power steering gear box
248,000 MILES • 6.6L • TURBO • 4WD • AUTOMATIC
FREEBIRD172
how do I remove the power steering gear box? How hard is it to replace the seals?
Mar 1, 2015 at 2:34 AM
HMAC300
  • 48,601 POSTS
your best bet on this is to get a rebuilt one instead of doing it yourself. Unless you have ever redone seals then you can really screw it up . If it is just the pitman arm seals the hardest part will be getting pitman arm off and you need snap ring pliers to replace the two seals inside.
Mar 1, 2015 at 2:43 AM
  • 55,817 POSTS
Check this video out,
http://www.youtube.com/watch?v=KKeFqHLuRQ0
Best Ken
Mar 1, 2015 at 2:46 AM
