Leaking power steering fluid
45,000 MILES • 1.1L • MANUAL
PAULINE JANE AMEY
My car keeps dripping steering fluid. It sounds very noisy too. but once i refill it, it is fine, then it does it again until empty, over two weeks of driving it .Would this be a big job , and what sort of price would I Have to pay to put this right ?
Jun 21, 2017 at 8:59 PM
CARADIODOC
  • 34,402 POSTS
We do not get involved with costs here because there are way too many variables. We do not even know what is wrong yet. Also, we do not have service information for your car. Judging by the engine size you listed, I am going to guess it is a front-wheel-drive, and as such, it likely has a rack and pinion steering gear. It is somewhat common for them to develop a leaking seal on one side. The lost fluid will collect in the accordion boot covering the inner tie rod end, but there is an air transfer tube that connects to the boot on the other side, so any leaking fluid can run out of both sides.
To verify this, slide off the small hose clamp on the end of one of those boots, then use a hooked pick or similar tool to pull the boot open. If power steering fluid runs out, the steering gear needs to be replaced. On some vehicles that job takes less than a half hour. On some it can take three or four hours if the vehicle is on a hoist. An alignment will be needed too when the repair is done.
Jun 22, 2017 at 7:32 AM
