Water leaking on drivers' side
143,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
BOB%
  • 71 POSTS
I covered the sunroof of my car with plastic, but after a lot of rain there is still a lot of water only on the driver's side. I had the fooif tubes checked and they were working properly. Is there any other possible place were all this water is coming from? Please help, thank you.
Nov 13, 2021 at 12:40 AM
Good morning,
I would check the seals around the door. A commonplace for leaks.
The other place is the windshield. If the seal is bad or the body is rusted, it will leak into the compartment.
The best way to verify is to take it through a car wash and watch for the water coming in. It will either be by the door or under the dash.
Nov 13, 2021 at 1:15 AM
