i have a 1995 Range Rover 4.0 SE. The water boils after 20 minutes of idle and i just had the cylinder heads rebuilt and the gaskets replaced. The temp gauge stays halfway. The mechanic says that the engine block may have to be rephased and i don't want to spend so much on the car. Can you advise what other possible causes are for the boiling water? How can i check if the blocks really have to be rephased? Thank you in advance!
Dec 10, 2008 at 3:49 AM
