2000 Rover 45 Heater Blows Cold
2000 LAND ROVER
ROBBIEP
Hi I really need someones help here!!I have a Rover 45 . My problem is that that the coolant level goes down dramatically whenever I put the heating on. There is 55k miles on the clock and the water pump ,belt and Head gasket where all done at 40k miles. If I don't turn my heating on everything is fine. However,my heating only blows cold air out and the coolant level drops when i put the heating on . I have no water in my oil or oil in my water ,the car never overheats ,the temp gauge needle never moves up just stays in the centre of the gauge . The only thing that happens is that the heater blows out cold air and my coolant level drops. I've been told it may a airlock but I've no idea how to get it out. please help!!!!
Jan 30, 2007 at 1:50 AM
DAVE H
  • 13,383 POSTS
empty the coolant system and flush out the heater core and cooling system .. refill with 2 litres of coolant .. start the vehicle, and continue filling system untill at the correct level ... this should alleviate any air locks !!
Mar 17, 2009 at 7:40 AM
Suggested Repair
Drain and flush the heater core and cooling system, then refill with about 2 litres of coolant. Start the engine and keep filling until the level is correct to purge air locks.
Conversation Summary
The owner of a 2000 Rover 45 says the coolant level drops and the heater blows only cold air when the heat is turned on. The car does not overheat, the temperature gauge stays normal, and there is no oil in the coolant or coolant in the oil. The water pump, belt, and head gasket were replaced earlier. An expert advised flushing the heater core and cooling system, then refilling while the engine runs to remove air locks.
