2000 Other Rover Models
NADIUS
  • 2000 LAND ROVER
  • V8
  • AWD
  • 82,000 MILES
My ABS light is on and I would like to know what could be the problem and how much would it cost to fix it?
Saturday, August 2nd, 2008 AT 9:16 AM
DAVE H
  • 13,384 POSTS
DIAGNOSTICS
While the ignition is on, the diagnostics function of the SLABS ECU monitors the system for faults. In addition, the return pump is tested by pulsing it briefly immediately after the engine starts provided vehicle speed exceeded 4.4 mph (7 km/h) during the previous ignition cycle. If a fault exists in a warning lamp circuit, the lamp will not illuminate during the lamp check at ignition on but, provided there are no other faults, the related function will otherwise be fully operational. If a fault is detected during the power up, the SLABS ECU stores a related fault code in memory and illuminates the appropriate fault warning lamps.
If a fault is detected later in the drive cycle, the SLABS ECU also sounds the audible warning three times. Fault codes and diagnostic routines can be accessed by connecting Textbook/T4 to the vehicle's diagnostic connector in the driver's footwell.
Fig. 20: Warning Lamp Fault Operation
Courtesy of LAND ROVER NORTH AMERICA, INC.
After detecting a fault, the SLABS ECU selects an appropriate default strategy which, where possible, retains some operational capability. A shuttle valve switch fault and throttle position signal fault are classified as permanent faults. If a permanent fault is detected, the related warning lamp illumination and default strategies are automatically employed in subsequent ignition cycles, even if the fault is intermittent, until the fault has been rectified and cleared from memory. If a non permanent fault is detected, the related warning lamp illumination and default strategies will only be employed in subsequent ignition cycles if the fault is still present.
After rectification of an ABS sensor fault, the ABS and ETC functions are disabled, and the ABS warning lamp remains illuminated after the lamp check, until vehicle speed exceeds 9.4 mph (15 km/h) (To allow additional checks to be performed).
Friday, November 27th, 2009 AT 10:44 AM
