2000 Land Rover Freelander
DEBBIE ROGERS
  • 2000 LAND ROVER FREELANDER
Electrical problem
2000 Land Rover Freelander Four Wheel Drive Manual 103000 miles
i am unable to open or close my back window and an alrm type beep is heard trying to do so. Also the rear demist and rear wipe is not working
Monday, March 8th, 2010 AT 3:31 AM
DAVE H
  • 13,384 POSTS
Check for body control system fault codes using a diagnostic scanner
The tail door window is controlled by the Central Control Unit (CCU), a rocker switch, the remote handset and the tail door handle and lock. The rocker switch for the tail door window is located on the fascia (up to 2004 model year) or the centre console (from 2004 model year). The CCU also uses inputs from the rear screen wiper system and, on 3 door models, a roof switch, to inhibit window operation while the rear screen wiper is operating or the roof is open (soft back) or removed (hard back).
Friday, March 12th, 2010 AT 6:24 AM
