1999 Land Rover Discovery 2 Runs Rough
XANGOTED
Engine Performance problem
1999 Land Rover Discovery 2 V8 Four Wheel Drive Automatic
Starts fine - idles fine - out of gear I can increase the RPM and it runs smooth.
In gear at about 25 mph and up - under load - (acceleration)- we get a vibration almost like a misfire.
If I let off the gas it stops.
Vehicle will coast with no vibration - only vibrates on acceleration.
Engine light came on -
We got codes that the forward Oxy sensors were slow to respond.
We have had also had codes for #3 and #5 misfires and now #6 and #8.
We have replaced plugs, tested wires, replaced forward oxygen sensors.
After replacing Sensors we still have vibration on acceleration but have been driving it for 5 days approx 300 miles and NO engine light. But still have vibration.
Apr 23, 2010 at 8:40 AM
  • 31,937 POSTS
Hi there,
Change the fuel filter and take a sample of fuel, draw it off and let it sit in a glass jar, check for water or other contaminates, start here.
mark (mhpautos)
Apr 23, 2010 at 9:08 AM
XANGOTED
There is no serviceable fuel filter on a 1999 Disc II V8.
So that idea did not work.
May 19, 2010 at 11:47 AM
  • 31,937 POSTS
There will be a connection at the fuel rail on the engine, undo that connection.
Mark
May 19, 2010 at 11:54 AM
