auto tensioner removal
174,000 MILES • 1.9L • 2WD • MANUAL
XPAULF
Hi. How do I remove the auxiliary belt auto tensioner on my car it is a DCI? When I loosen the tension to remove the belt, the spanner is under tension and is difficult to remove. The tensioner is retained by a bolt which I can loosen. But if I remove the bolt will the tensioner not suddenly spring off.
Aug 16, 2016 at 3:07 AM
  • 55,781 POSTS
Sometimes you need to use a large pry bar to hold tension against the pulley and then remove the belt. The designers at expect you to have a special tool they their mechanics have only so you will need to be innovative.
Please let us know what you find so it will help others.
Best, Ken
Aug 21, 2016 at 1:55 AM
