Knocking noise in the dash board
2012 CHRYSLER 300
140,000 MILES • 2WD • AUTOMATIC
DUSKY KELLINGSWORTH
When I shut my car off there is a knocking or clicking noise that comes from inside my dash on the drivers side. The knocking/clicking continues for as long as fifteen minutes after the car is turned off.
Nov 13, 2018 at 7:25 AM
  • 110,244 POSTS
Often times, a clicking is attributed to a faulty temp, mode, or air flow actuator. These actuators are responsible for changing air flow directions, providing fresh air, or temperature control. Inside the actuators are plastic gears. What happens is the teeth on the plastic gears strip. As a result, you hear plastic gears clicking together until it finally turns and the cycle is complete.
Take a look at this link. It shows how in general a blend/temperature actuator is replaced. Also, it describes what happens and what you hear. Read through this and let me know if you feel it mirrors the symptoms. If it does, we need to determine which actuator is bad and then I can provide directions for replacement.
Let me know your thoughts.
Nov 14, 2018 at 11:02 AM
DUSKY KELLINGSWORTH
Thank you! I will follow the link.
Nov 15, 2018 at 12:07 AM
  • 110,244 POSTS
You are very welcome. If you need help or directions, feel free to let me know.
If I don't hear from you, have a good Thanksgiving.
Nov 15, 2018 at 10:16 AM
