Knocking I had a push rod that was out of place and the rocker arm?
82,350 MILES • 3.3L • V6
DBUSLER
I had a push rod that was out of place and the rocker arm it was on cracked. I replaced the rocker arm and shaft because a few of the arms locked up. After I got everything back in I test drove it and I heard a knock and I'm not sure what's causing the problem I have not checked the oil pressure yet or the timing but those are the only things I can think of that would cause to problem and I have new oil in it and at the right level.
Oct 9, 2023 at 1:43 AM
  • 55,594 POSTS
Does the knocking seem to come from the top of the engine or the bottom? If the bottom you could have a rod knock and if it is from the top of the engine. Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response.
In the meantime, here is a guide on engine knocking:
https://www.2carpros.com/articles/understanding-and-repairing-engine-knocking-noise-an-in-depth-guide
Please go over this guide and get back to us.
Oct 9, 2023 at 3:38 AM
