Knock sensors codes P0332 and po327
112,000 MILES • V8 • AUTOMATIC
MISS CHARLEE
I replaced the knock sensors with su7012 instead of su7015 sensors. I was informed they are the same except the 7012 sensors are 3 inches longer. After replacing them, nothing has changed. Vehicle still runs rough and reads restricted performance along with engine light. When thermostat housing was changed hose was not connected and coolant ran out everywhere. Please tell me what the problem could be. Did I damage sensors when putting them in
Nov 29, 2015 at 11:44 AM
HMAC300
  • 48,601 POSTS
if you overtorqued sensors then yes you damaged them but check wiring it could be that as well those codes are poor ground to block so check that especially if you put sealer on them also check ground to battery from engine and body
Nov 29, 2015 at 11:08 PM
