Knock noise on front passenger side when turning
200,000 MILES • 5.0L • 6 CYL • 4WD • AUTOMATIC
MOORE4
When I turn I hear a loud knock on the front passenger side.
Dec 5, 2020 at 3:05 AM
More then likely this is a loose suspension component like a ball joint, or control arm, or even part of the steering system.
Can you get a recording of the noise? Does this happen when turning both directions and how hard to you have to turn? What about moving or sitting still?
The last thing I am thinking is it could be a loose wheel so we need to check that as well.
https://www.2carpros.com/articles/wheel-removal-and-re-installation
Here is a video on replacing a control arm on a Chevrolet which will help if we go that direction:
https://www.youtube.com/watch?v=E51EvOGnPf0
But let's start with a video of the noise so we can hear it and go from there. Thanks
Dec 5, 2020 at 11:20 AM
