2001 Kia Sportage Grinding noise
2001 KIA SPORTAGE
153,744 MILES • 4 CYL • 4WD • AUTOMATIC
CKENT70
There is a grinding noise coming from the front of my car. I had the wheel bearings replaced, new muffler installed and new brakes placed. This noise is still there.
I had two mechanics check for the problems and they could not find the problem. frustrated!
thanks
Feb 27, 2010 at 1:26 PM
  • 31,937 POSTS
Hi there,
When exactly do you hear the grinding?
mark (mhpautos)
Feb 27, 2010 at 1:57 PM
CKENT70
As soon as I start to drive and the car is in motion. Sometimes it will stop for a bit then start right up for the rest of the drive. I feel it more on the drivers side.
The noise is loud. Grinding, squeaking, and sometimes a thumping sound.
Thanks
Feb 27, 2010 at 11:47 PM
  • 31,937 POSTS
Hi there,
Brace the car and jack up that wheel, turn it by hand, can you hear the noise? can you feel any movement (top to bottom ) in the bearing, check that the brake backing plate is not touching the rotor, if you can hear that noise at that wheel, advise your mechanic to do a full inspection around this point if you feel you cant do the job your self.
mark (mhpautos)
Feb 28, 2010 at 7:16 AM
