2001 Kia Spectra stalling
FIEND55
Engine Mechanical problem
2001 Kia Spectra 4 cyl Two Wheel Drive Automatic
it stalls badly like it wants to cut off but hasnt yet and seems to be getting worse...what problems could cause this and the most reliable solutions?
Jul 11, 2009 at 6:20 AM
  • 110,251 POSTS
Has the check engine light come on? Have you checked for vacuum leaks? Also, fuel pressure can be an issue. Have you checked fuel pump pressure or the fuel filter?
Here is a HOW TO for checking fuel pump pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Oct 14, 2009 at 1:17 AM
