1999 Kia Sophia fuse
1999 KIA SEPHIA
164,000 MILES • 4 CYL • FWD • AUTOMATIC
SHEILA_SBS
My car keeps shooting the fuse labeled ECU. If the weather is cold outside it runs fine but if the temperature gets around 50 or higher and I get stopped at a light for very long the fuse shoots when I take off. Any ideas?
Dec 10, 2008 at 6:03 AM
JAMES W.
  • 2,394 POSTS
Sounds like you have an input sensor wire grounding out some where on the ECM system. I would look at anything that moves when you take off from a stop. ie; throttle position sensor, along the throttle or brake linkage, anything that would move on braking or takeoff. Good luck.
Dec 10, 2008 at 8:08 AM
