Right front tire roares when driving or turning to the left will not roar when turning to the right. Have replace the cv joint
Friday, January 23rd, 2009 AT 10:18 AM
MECHANIC
Hi:
A roar will never be a cv-joint. CV-joints click when bad. If it is a roar that is only heard when you turn right, you have a bad right wheel bearing. When you turn left, much more weight is placed on the right wheel. When you turn left, the weight is taken off the right wheel and the noise decreases. Make sure it isn't something like bad tire wear, but chances are it's the bearing.
