2002 Kia Rio
99,000 MILES • 4 CYL • FWD • AUTOMATIC
SAXOPHONE7
I have a 2002 kia rio sedan. I was tring to figure out why my interior dome light didn't work. I was checking to see if power was going to the light and to my surprise there was. Unfortunately, I accidentally completed what should of been an open circuit and the ground and live pieces touched. To my frustration, there was no longer and power going to the light. I checked EVERY fuse in the car that I could find and they all were good. I then turned on my car and found that the radio doesn't work anymore! It worked before and now it doesn't. I have no clue what i did. What did I do? Even more helpful, how the heck do i fix it???
Jun 7, 2008 at 1:38 PM
KHLOW2008
  • 41,812 POSTS
Hi saxophone7,
Firstly the dome light either has a loose contact or was fused. Replace the bulb if necessary.
Secondly you short circuited the power supply and caused a blown dome/radio fuse.
I am not familiar with the fuse layout of this vehicle so you need to check for a room light or radio fuse.
If it is not under dash, then it should be under the bonnet.
Jun 8, 2008 at 1:34 AM
