2001 Kia Rio mounts
ROBERTARKME
  • 2001 KIA RIO
  • 4 CYL
  • MANUAL
  • 200,000 MILES
The mounts are GONE. Bought 2 new ones. I know the front from the back.
There is a direction to the mounts. # 2 which is on the front of the car, drivers side and # 1 which is on the drivers side back. The rubber tabs on the mounts, do they go inside the mount supports or out. The fabrication shows that there has to be a direction. I even called a Kia tech, and they won't release the info. Can you help. Thanks. Rob
Tuesday, June 24th, 2008 AT 1:31 PM
KHLOW2008
  • 41,814 POSTS
Hi robertarkme,
The tabs are cushions to prevent the brackets from hitting the mount.
They are installed between the bracket and mount on either side, seated on the mount centre pin.
Saturday, June 28th, 2008 AT 11:52 AM
Related General Content
