1997 Kia Sportage Timing Belt Due
Why did you have to do a tune up
And what exactly did they do.?
Why are they saying you need it?
Do they know when it was last done...or if it is due?
I'm not saying they are right or wrong, just need facts to help out.
range/performance malfunction and # P0750 shift solenoid malfunction. Since I just had the gear shift replaced it was under warranty so I went back to the dealership to have that replaced but the dealership said that was not the problem and that what was wrong was that I needed to have a tune up. I did could not believe the price they told me so I took it to a 3rd place who told me the same thing as the 2nd place told me. This is what the papers
said was done: Tune up; spark plug wires set; spark plugs; fuel filter. They also repaired the harness connectors, cleaned and tightened terminals in connectors C-123 and C-124; cleaned grounds #G103, G104 and G105, and rerouted wiring harness to gain more slack.
I do not know if or when the timing belt was replaced because I have only had the car for 5 months. I know we have not had it done. They told me we should replace timing belt because the car has over 60k miles on it. It had 88k when we bought the car.
Paul
Suggested Repair
Confirm whether the 1997 Kia Sportage has California or federal emissions using the under-hood sticker or the VIN at a dealer. Because the timing-belt history is unknown, mileage is about 89,000, and the DOHC is an interference engine, replace the timing belt if it is overdue rather than waiting for noise or other warning signs.
Conversation Summary
The owner of a 1997 Kia Sportage with about 89,000 miles asked why a shop recommended a timing belt when the vehicle was running well and making no unusual noises. After clarifying prior repairs and codes, the expert explained that the DOHC engine is an interference design, so a broken belt can damage the engine without warning. The owner was advised to identify the emissions specification, compare it with the applicable interval, and treat an unknown service history as a reason to replace an overdue belt. The owner accepted that advice.
