2005 Kia Amanti fuel filter
2005 KIA AMANTI
62,000 MILES • 6 CYL • FWD • AUTOMATIC
CHRIS2PHERNKC
Where is the fuel filter on a 2005 Kia Amanti? Is it possible to change one?
Dec 31, 2008 at 11:08 AM
DAVE H
  • 13,384 POSTS
FUEL FILTER
REMOVAL
Open the service cover in trunk room.
Reduce the internal pressure of the fuel lines and hoses:
Disconnect the fuel pump harness connector.
Start the engine and wait until fuel in fuel line is exhausted. After the engine stalls, turn the ignition switch to the OFF position.
Disconnect the battery negative (-) terminal.
Disconnect the fuel feed hose and the fuel return hose.
Unfasten the bolts (6) and remove the fuel pump assembly from the fuel tank.
Remove the fuel filter holder and disconnect the connecting hose and the cable assembly, and then remove the fuel filter & pump assembly.
Apr 11, 2009 at 1:15 AM
