Key will not turn
190,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
GDAMBROS
It was away for 2 months, and the battery drained. Charged battery to 12.4 Returned and when tried to start car noticed steering wheel was not locked and key would not turn in ignition. The message was "remove key, turn steering wheel, restart." This did not work. Key will not turn out of locked position, steering wheel remains unlocked.
May 12, 2022 at 7:50 PM
  • 110,246 POSTS
Make sure the transmission is fully in the park position. Also, take a look through this link to see if it helps in any way.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Let me know if this helps.
May 13, 2022 at 2:04 PM
