Key removal
2008 MERCURY MOUNTAINEER
199,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
NICK DEWINTER
There is a pin on the shifter assembly that keeps backing out preventing the removal of the ignition key. Wondering if the pin may be worn or hole damaged my mechanic says it is not, but the problem happens periodically. Is there a fix? It is getting aggravating.
Oct 9, 2018 at 8:45 AM
  • 55,221 POSTS
It is hard to say. What you are talking about? Can you please upload picture of what you are talking about?
Oct 11, 2018 at 7:14 AM
STEVE W.
  • 15,295 POSTS
If the pin is the one at the top of the pivot above the shift interlock solenoid that goes through the plastic it is possible the hole is worn. I have used loctite on loose parts like that. The bearing retainer type seems to work best.
Oct 11, 2018 at 7:34 AM
NICK DEWINTER
Thanks Steve.
Oct 11, 2018 at 9:24 AM
