Key fob programming instructions needed
208,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
UHSNOEBIRD
  • 342 POSTS
Does anyone know how to program a key fob that has never been programmed for this vehicle? but without using a locksmith or dealership programming it for me. I need a home remedy if anyone has one. I've looked online and not found anything that will work.
Oct 5, 2020 at 10:51 AM
  • 110,248 POSTS
First, here is a link that explains how to reprogram a keyless remove (fob):
https://www.2carpros.com/articles/how-to-re-program-a-key-remote-fob
However, according to my manual, to program a fob requires a scan tool that can communicate with the vehicle's remote keyless entry system (RKE). Here are the directions I have:
_______________________
2002 Saturn L200 L4-2.2L VIN F
Transmitter Programming
Vehicle Accessories and Optional Equipment Antitheft and Alarm Systems Keyless Entry Keyless Entry Transmitter Service and Repair Procedures Transmitter Programming
TRANSMITTER PROGRAMMING
Each transmitter is coded to prevent another transmitter from activating the RKE functions on another Saturn, as long as that particular transmitter has not been specifically programmed to that Saturn.
A transmitter can be programmed to as many different Saturn's as a customer owns, as long as they have the power door lock option. Each Saturn can be programmed with up to four transmitters.
To program transmitters use the Tech 2 BCM special functions, Program Key Fobs.
To program customer options refer to "RKE Customer Programmable Content Theft Programming".
___________________________
See if the link helps. If it doesn't, let me know.
Oct 5, 2020 at 12:22 PM
STEVE W.
  • 15,411 POSTS
As Joe related the remote for that car must be programmed using a scan tool. That is common with many vehicles as a way to prevent theft. There are shops other than the dealer who can program them in as well as locksmiths, the locksmiths are usually the lower cost option though.
Oct 5, 2020 at 1:34 PM
UHSNOEBIRD
  • 342 POSTS
Joe, that link didn't help me. I'm needing a key fob programmed without going to a locksmith or dealer.
Oct 10, 2020 at 5:57 AM
STEVE W.
  • 15,411 POSTS
It isn't possible to program that vehicle to use a remote that has never been initialized to it without a scan tool and security access. That means a shop with the correct tools or a dealer or locksmith. No DIY method on that Saturn.
Oct 10, 2020 at 8:08 AM
UHSNOEBIRD
  • 342 POSTS
Thanks.
Oct 10, 2020 at 10:58 AM
  • 110,248 POSTS
I'm sorry that didn't help. Steve is correct. You need security access initialized. I wish I had a better answer and less expensive one for you, but unfortunately I don't.
If you have a chance, let us know if you get it taken care of.
Oct 10, 2020 at 11:04 AM
UHSNOEBIRD
  • 342 POSTS
what diagnostic scanners programs a key fob for my vehicle that doesn't cost to much ?
Oct 12, 2020 at 7:39 AM
STEVE W.
  • 15,411 POSTS
The only lower cost unit that does any key or fobs that I'm aware of is the Launch Diagun V and it run's about $700.00+ for the basic unit and I'm not sure it would work on a Saturn as it's somewhat hit or miss on that function based on what the OEM sets up in the system. Many require a PIN number that you cannot get without a dealer access code that allows the system to accept the new device into the system, again to prevent it being easy to steal vehicles.
Oct 12, 2020 at 8:38 AM
UHSNOEBIRD
  • 342 POSTS
that's too much money. thanks
Oct 12, 2020 at 11:23 AM
STEVE W.
  • 15,411 POSTS
That's one of the problems. None of the lower priced units do anything with the security systems. I have 2 scan tools that will program just about any keys or fobs, one was $2,400.00 and the other was closer to $7,000.00 plus both require a subscription to a security service to work. That is why I usually say that a locksmith or smaller shop with the tools is a lot cheaper. Usually a dealer is good as well but 99% of the time you need an appointment and the time to drop it off, with a locksmith you can usually drive in and get it done in a half hour. Unless you run a shop or a mobile diagnostics outfit it isn't something for a DIYer to get into these days.
Oct 12, 2020 at 1:37 PM
UHSNOEBIRD
  • 342 POSTS
I'll probably just use my keys. thanks for your answers.
Oct 12, 2020 at 1:39 PM
STEVE W.
  • 15,411 POSTS
That is an option. Thank you for using 2CarPros.
Oct 12, 2020 at 4:24 PM
