Keeps cranking
16,000 MILES • 3.7L • 4 CYL • AUTOMATIC
TKITEZ
Start my car keeps cranking turn, off then turn on ignition and it starts. engine warning light came on while driving. replaced fuel filter light went out. Now turn on ignition faint fuel pump noise starts okay, sometimes and runs well no other issues.
Aug 9, 2020 at 4:54 AM
Good afternoon,
Can you give me the code that was set for the light? You can go to a parts store and have it read for free.
There is no code for the fuel filter so that had nothing to do with the light.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
I would check the fuel pressure to be sure it is correct and the fuel pump is good.
Aug 9, 2020 at 5:09 AM
