Junkyard Gen 3 lower end
116,000 MILES
BPADRNOS
  • 5 POSTS
I got what I was told was a 2002 LM7 w 116,000 miles on it. Pulled the cam and lobes and journals look great but I can see copper coming through on the bearings. so I am going to change those out along with the lifters. But what is your opinion on the bottom end? pull the rod caps and plastigage the bearings at a minimum? just leave it alone and go with it? This is going into a 64 Coupe de Ville so it's just a cruiser so not looking for big power, just want dependability.
Thank you and great YouTube videos.
-Brian
Feb 3, 2021 at 9:59 AM
STEVE W.
  • 15,414 POSTS
I would go through it completely, if there is copper showing it was likely run hard to get that much wear. Plus you would have a known starting point with the internals as you can flush out the block, check the bores for wear and at a minimum replace the bearings and rings with a light hone of the bores. Then go over the heads the same way, clean them, and at a minimum new stem seals and lap the valves to see what the seats look like. It won't be a new engine but refreshed enough that it should run well and give dependable service.
Good luck with it. Those are a nice car to make a cruiser out of.
Feb 3, 2021 at 4:43 PM
