jitters on drive gear at stop light
2003 LINCOLN TOWN CAR
123,000 MILES • 4.9L • V8 • RWD • AUTOMATIC
PAULIKORG
ok here goes,i HAVE DOCUMENTED THIS MANY TIMES SO I KNOW ITS NOT A FLUKE...Car runs beautifully,only one issue and it is as follows....when I come to a stoplight and if it last longer than 20 seconds the car will shake and feels like its missing, when light turns green I will go and after a few seconds the shaking will stop and it runs smooth again.Now...if I put it in neutral at a stop light this does not happen.
THIS IS NOTED.....if the stop light lasts for over a minute the engine will start to shake and it last for approx.
20 seconds then it resumes its smooth idle again,so it sort of goes thru a cycle of some sort.I have been keeping notes on this for a few weeks now and it happens the same always. Stopped at a red light for longer than 20 seconds the idle will get rough and shakey,this lasts for about 20 seconds then goes away.Time after time..its like clock work .Is there some kind of timing thing in the computer that makes this happen.Granted Ive only had the car for a month and haven't done any tuneup except take out the MAF sensor and spray clean it.A friend suggested I do this
This didn't stop the problem.Any help would be greatly apprieciated....thanks,Pauli
Feb 6, 2014 at 7:00 AM
MLDANIELS2000
  • 227 POSTS
Check for coolant leak at heater hose coming from right rear of intake plenum. Common problem with these cars was bad plastic intake plenum would leak coolant down around spark plug coil boot and allowing misfire. Was more pronounced when vehicle is in drive due to load on engine when transmission is in gear. Happened to my car. New intakes are $250 and are updated due to this problem.
Feb 6, 2014 at 7:11 AM
PAULIKORG
Thanks I will try that and get back to you.........pauli
Feb 6, 2014 at 7:25 AM
