Jerks when accelerating in lower RPM's
108,000 MILES • 3 CYL • 2WD • AUTOMATIC
CJCJCJ01
Been doing this for about a year now getting worse. Took to mechanic no code showed up. He charged A/C thinking when the A/C kicks on and off it pulls from the small engine causing the jerking. Seemed to work okay for three -four days now back to doing the same.
Jul 12, 2021 at 8:03 AM
  • 110,244 POSTS
Are you only feeling this when the A/C compressor engages and disengages? If it does it with the A/C off as well, has anyone checked fuel pressure to see if there is an issue or for an engine vacuum leak?
Here are a couple of links showing how it is done:
Also, has the vehicle been tuned up (new plugs) or anything electrical been checked?
Jul 12, 2021 at 2:42 PM
CJCJCJ01
Will keep you updated thanks.
Jul 13, 2021 at 2:59 AM
