Trouble Starting
JEEP WRANGLER
MUDWOLF69
1998 Wrangler Sport 4.0 - 6 cylinder Automatic Gas gauge not registering, wants to turn over but will not. Fuel pump not turning on when turning ignition but is working when I have pulled it out of gas tank & tested it. Battery is ok, coil is ok, fuses are ok, relays are ok, won't turn over in park or neutural, tried using a auto scanner I keep getting an error reading. Scanner was checked on another vehicle and it was working ok. Sprayed starter fluid in the throttle and it did start briefly. Any suggestions I need your help!!! :evil:
Aug 25, 2007 at 1:22 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
Check the fuel pump fuse and relay, then check the green/wht wire at the tank for power...
Aug 26, 2007 at 12:09 PM
