2001 Jeep Wrangler negative battery cable
2001 JEEP WRANGLER
WILLIES_WIFE
Electrical problem
2001 Jeep Wrangler 4 cyl Four Wheel Drive Manual
how do i replace the negative battery cable?
Mar 12, 2009 at 7:23 AM
MERLIN2021
  • 17,250 POSTS
Loosen the nut at the battery end, twist until cable comes off the battery, or use a cable puller, or spread jaws with a screwdriver. and remove. Then follow it to the engine block attaching bolt, remove that, clean the block area and install new cable.
Mar 12, 2009 at 7:38 AM
