1999 Jeep Wrangler Jeep Wrangler Sputtering/Stalling when h
1999 JEEP WRANGLER
91,000 MILES • 6 CYL • 4WD • MANUAL
SHAMROCK0211
I have a 1999 Jeep Wrangler with 91,000 miles. When it is hot out, it will drop RPM's rapidly and "sputter" as it it wants to stall. It happened to a lesser extent last summer and then was fine all winter. This summer it has gotten worse. It has stalled out a few times due to this, once on the highway while I was doing 65. I pull over and it re-starts no problem and I can drive away right then. When the happens, the RPM's drop to 0 then kick back in after a sputter. The electrical in the car is still on and I have to turn the car completely off and restart it.
Also sometimes when I fill up, the gas pumps kicks back saying I am full but when I re-start the car it shows 3/4 tank. Not sure if this is related but I figured I might as well bring it up as it might be key to someone in the know.
I am not a car guy, hence I am asking the question here. But to me it seems that the fuel pump is either overheating or a relay switch somewhere is burning out. Like I said it only seems to happen when the weather turns especially hot. Usually after I have been driving for 45 minutes or so.
Jun 21, 2010 at 3:16 PM
RACEFAN966
  • 5,029 POSTS
Is teh check engine light on? If it is go to your local parts store or find one that will do a free scan and scan it and get back to me with the codes.
Jun 22, 2010 at 3:39 AM
SHAMROCK0211
No the check engine light is not on, nor does it come on when the engine sputters
Jun 22, 2010 at 3:48 AM
RACEFAN966
  • 5,029 POSTS
Ok the only way to find out if it is the fuel pump is to check the fuel pressure while it messing up to see if the fuel pressure is dropping off. If you can't do this yourself then you should find a shop that is willing to run a fuel pressure test while running to see what it does when it starts to stall out. It should stay between 44 to 54 psi.
Jun 23, 2010 at 2:38 AM
SHAMROCK0211
Took it in to Midas. After 2 days of testing looks like it was an crank position sensor. They said it was very common in Chrysler models. $300.00 out the door.
Jun 23, 2010 at 3:01 PM
RACEFAN966
  • 5,029 POSTS
Yes it is a common problem but I was under the understanding in you first post it was check my bad should not assume. Glad to hear it is fixed.
Jun 24, 2010 at 2:51 AM
