Check the oil pressure before you drive it to much. Something made the push rod fail for you. If its low than it is possible that yoiu have worn rod bearings and main bearings. If they have not scarred the crank I have gotten away with installing new ones and getting alot of miles out of the engine. You will need to plasti gauge all the bearings to know where your at. Just make sure the crank has no damage. Let us know Curt
Sunday, February 8th, 2009 AT 11:05 AM
