1997 Jeep Wrangler Radio Cuts out
GLENNMM
Electrical problem
1997 Jeep Wrangler 6 cyl Four Wheel Drive Manual
When the turn signal or the wiper is used the radio cuts out. It dosen't happen with the flashers. I took the switches out of the column but they appear OK. This just started happening. Radio works OK when just sitting or driving as long as the wipers or signals aren't used. Any thoughts?
Jun 23, 2009 at 4:50 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Check at fuse 12 for abnormal voltage and current when the wipers or the turn signal is activated. My guess is that the voltage will drop below the required amount for the unit to operate.
https://images.2carpros.com/forum/automotive_pictures/187088_Entertainment_2007_Diagram_1.jpg
Jun 30, 2009 at 3:17 PM
GLENNMM
Thanks. We finaly pulled the radio out and checked all the voltages at the connectors. Could not get any lower voltages than 13.5. It would drop from13.65 to 13.5 when the signals were working. We installed a new radio and have no problems. Must been something in the power supply of the factory radio. Thanks again.
Jul 3, 2009 at 7:08 AM
AIRSOFTSOLDRECN9
  • 348 POSTS
Good to hear that. If you found my information helpful (or unhelpfull) please leave feedback. It is greatly appreciated! Happy wheeling!
Jul 5, 2009 at 3:52 PM
