1995 Jeep Wrangler two minutes of cranking before the engin
1995 JEEP WRANGLER
JAKEFRIEDL@YAHOO.COM
Engine Performance problem
1995 Jeep Wrangler 4 cyl Four Wheel Drive Manual
it takes forever for the jeep to start. i can crank for two minutes before it starts, i replaced the fuel pump, wires ,distributer cap roter, coil, and it still does the same thing
Nov 16, 2009 at 6:41 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
Its a check list need to go through
Check battery and battery terminals
Check spark at the coil and it should be strong
check fuel pressure and do a fuel system leak test
Nov 16, 2009 at 8:07 PM
