1995 Jeep Wrangler two minutes of cranking before the engin
JAKEFRIEDL
  • 1995 JEEP WRANGLER
Engine Performance problem
1995 Jeep Wrangler 4 cyl Four Wheel Drive Manual
it takes forever for the jeep to start. I can crank for two minutes before it starts, I replaced the fuel pump, wires, distributer cap roter, coil, and it still does the same thing
Monday, November 16th, 2009 AT 6:41 PM
BMRFIXIT
  • 19,053 POSTS
Its a check list need to go through
Check battery and battery terminals
Check spark at the coil and it should be strong
check fuel pressure and do a fuel system leak test
Monday, November 16th, 2009 AT 8:07 PM
