I have a jeep wrangler 1992 4.0 engine manual transmission. The problem is that the temperature goes up when going over 65 miles (up to 3/4), I have the engine rebuilt (this happened before this too), new radiator, new thermostat, new water pump, I replace the fan to an electrical system, and there is no obstruction for the air to flow in the front. Other wear issue is that the manifold goes red hot when over 2500 RPM. I replace the distributor too, but now I was told that this could be because of a bad computer, any ideas of what can be wrong or if it's possible to be cause by the computer?
Sep 9, 2008 at 7:13 PM
