I have just purchased a 1991 wrangler yj with bad rear axle. The Spider gears sheared and damaged the ring and pinion along with the case assyembly. The axles are not damaged. I am looking at the metal tag on the housing and it says 4 11. The front has a tag that says 4 10. If I go out and look for another axle, is a 4 11 ok or do I need to match the 4 10 in the front? I am pretty sure with all my research that the rear is a Dana 35 and the front is a Dana 30. I am very new at this so any help would be greatly appreciated.
Thanks. JJ
SPONSORED LINKS
Saturday, May 3rd, 2008 AT 12:00 AM
