There should be a bleeder down on the slave cyl? If not there then it is up high on the master cylinder. Please make sure you have the right parts before you begin. Also if there is no bleeder ( and I have seen this on a few modles.) Bleed like you do brakes and ENSURE you do not run out of fluid in the mstr cyl. Also if yoiu cannot get a good bleed on the clutch then just tap the brake pedel with your toe or foot. This helpts o dislodge the airbubbles and they will rise to the top through the. Hope yyhiod helps
you.
SPONSORED LINKS
Monday, April 27th, 2009 AT 9:55 AM
