I have seen this done but you need to be aware of the one modification. The tops rear hatch on a 91 rides on the outside of the tailgate and the earlier tail gate was designed to ride outside of the hatch. You will have to modify one or the other to make them mate. Dont just put the top on and slam the hatch down with the gate up or it will shatter the glass. You will also probably have some problem with the upper doors on half doors and also you might not fit if you are running hard doors, if I remember correctly the upper part of the top is formed differently. Hope this helps. Curt
SPONSORED LINKS
Monday, December 1st, 2008 AT 9:37 PM
