I would strongly urge you to flush the brake system. The vehicle has not been driven much and brake fluid has a bad way of pulling moisture into itself. It also sounds like you have a problem with your front brake lines. After time they begin to deteriate on the inside and they trap pressure one way causing the caliper to not release. Pull the calipers and make sure they are clean on the sliding areas and the pistons press in firmly but easily. But I bet its your brake lines. Hope this helps. Let us know Curt
SPONSORED LINKS
Monday, March 15th, 2021 AT 2:35 PM
